Phone has a pink shade on 3/4 of the screen?
How can I fix this issue?
Это хороший вопрос?
Rinku Master this sounds like a bad display since it is only showing on parts of it. Most likely will require a new display assembly. Samsung Galaxy Note9 Display Assembly Replacement
Был ли этот ответ полезен?
Hi,
Just to add to the answer above, try starting the tablet in safe mode just to eliminate the remote possibility that it is a software problem that is the cause of the problem.
If it also display the same when in safe mode try a screen replacement as suggested above.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 743
