The floor lights on the handle are flashing and the floor piece will n
The floor lights on the handle are flashing and the floor piece will not run. I believe it's the wiring, is it replaceable
Это хороший вопрос?
Оценка
0
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 29
I have the same problem except it is intermittent. The vacuum works fine for a little while then all three floor lights start flashing in unison and the brush in the floor unit stops spinning. I can switch the unit off for a few minutes then start it again and it will run normally for a few minutes then shutdown again. I suspect there may be a thermal overload protection device like a thermocouple switch in the floor unit that is faulty. I have not been able to find a service manual for the unit that explains what it means when all three floor lights on the handle flash in unison.
из Jim Manley
