My MacBook Pro’s battery is swollen and it don’t turn on nor charge?
It’s 13 inch early 2015.
I found my MacBook dead suddenly . Later I opened it up but found that the battery is swollen and after that I tried to unplug the battery and turn on the Mac using AC POWER but it didn’t turn on?
Это хороший вопрос?
Оценка 0
Комментарии:
can-i-run-macbook-pro-retina-13-inch-early-2015-without-a-battery?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
First and foremost, you need to replace the battery. Be careful with this as the batteries on the 2015 pros are adhered in and are a pain to remove. I recommend liberal amounts of 99%ipa. Second. Make sure you have the proper voltage adapter. If you have an undervolted adapter it will not provide enough power. I also recommend using an OEM adapter.
Был ли этот ответ полезен?
Оценка 3
Комментарии:
I am not sure if the issue is only related to the battery or the board? I tried to turn it on with AC power supply but it did not work.
из
Добавьте свой ответ
Jahid Hasan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 43
