Battery PCB Solder Pads Missing
Hi all, I hope someone can help.
I need to run jumpers from the missing solder pads for the battery connection but I’m unsure to what points.
Can someone with knowledge please advise?
Images below from microscope.
Help is greatly appreciated.
Это хороший вопрос?
Hate to ressurect an old one, but I have the opposite problem. I have those 2 pads in tact, but the one he has intact I have missing. Is there a test point for that one?
из tyler.moran.iphotoshop
@tyler.moran.iphotoshop I'm sure there is a place to run a jumper. The picture from the original post is harder to make out for the other pad because there is glare or notation in the areas where traces run around that pad. Typically you can just read the board, look where traces from that pad seem to go and/or check for continuity between points. I might consider posting a separate question so you can upload your own pictures.
из Alisha C
