Headlights and staeter, no response.
New battery, horn, signals, brakes lights work. Headlights and staeter, no response.
Это хороший вопрос?
Это хороший вопрос?
wolfgreimann you forgot to tell us what you have checked and what the outcome of those checks were. Here are the wiring diagrams for your scooter including the starting system. Please remember that
If the main switch is set to “ON” (switch is closed), the starter motor can only operate if at least one of the following conditions is met:
The sidestand switch is up (the side stand switch is closed), and the brake lever ( front or rear) is pulled to the handlebar (the brake light switch is closed)
This means that you have to make sure you check all of those switches as well
Download those images and open them in your graphics program. that way you can seriously enlarge them
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 190
