Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Вопросов 20 Показать все
Is my logicboard damaged or is my lcd damaged
I dropped my ipad on the backside and a cluster of dead pixels appeared and whenever it displayed something dark colored, lines would appear on the screen. the touch still works though. now there is a black curved line on the top right corner of the lcd and the screen is completely filled with lines. the screen still displays the colors of my wallpaper. I’m wondering is this just a lcd issue or a lcd and logicboard issue. i forgot the mention that images were also becoming more pixelated as well
Update (11/10/2020)
I will give an update after the repair. Wish me good luck
Update (11/10/2020)
plus i forgot to mention that my lcd was glitching after the drop. is this a sign that the image filter on the board was damaged
Update (11/12/2020)
I fixed my iPad mini 3 screen and there are no problems now. There aren’t any signs that anything was damaged on the board that are visible on the display. Thank you to all people who gave advice
Update (12/09/2020)
Bad news: my ipad lcd is going nuts again. It randomly had lines making it unusable. I don't know the cause. Do you think it could be defective? Should I replace the lcd again
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
It sounds to me like you need a screen replacement. Some phone and tablet parts suppliers will sell you a screen and give you a refund if it turns out not to fix the problem. But ony, of course, if you’re sufficiently careful with it to return it exactly as received.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
I am wondering if my ipad logicboard is damaged because some people say that the image circuit on the logicboard can get drop damaged and can result in bad image. hopefully it isnt damaaged in any way. Wish me good luck for when I fix my ipad!
из
plus my lcd is kind of glitching. could this be signs of logicboard damage
из
Bad news: my ipad lcd is malfunctioning AGAIN. While i was using it, the screen decided to randomly become blurry. It was blurry with lines. I couldn't fix the issue. Should I replace the lcd again?
из
Добавьте свой ответ
brianlin4599 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 137
