PowerBook 3400c change the clock,
Powerbook 3400c-I can't change the clock, it shows me 11/10/1920 and it should show 10/11/2020.
I formatted the disk and installed a new program and it's the same. did not change the clock.
Это хороший вопрос?
Это хороший вопрос?
Go into the Date and Time preferences and set your Time Zone, then set it to automatic update with Apple America.
Был ли этот ответ полезен?
It still shows the same, no change
Could you initially change it, and then it reverted back? Is your battery bad?
this time set error uccurs under Os 8.5 and older, I didnt have problems after the 8.6 update or in Os 9.1.
also, there is a small app that can be used to correct time/date.
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 95
