Broken LT trigger Replacement parts
The little component of the circuit board which is activated by the LT trigger is constantly activated. I disassembled it and found all the mechanical functions of my LT button we’re in good shape. So I narrowed it down to the the component on the circuit board it was attached to. I was hoping to replace this component since it seem to be faulty, but when I looked online my problem seemed to be a one off thing. I then tried looking a circuit board diagrams for the part number. Didn’t find a good one for identifying the part. I was hoping someone here would be able to point me in the right direction to replace this part without replacing the entire mother Board.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Search “trigger potentiometer”, you can find them by the bunch.
Although it is going to be a difficult repair, you have to desolder it from the flimsy controller board, which often gets overbaked and traces will fall off the board. Also you have to mind not to melt other plastic parts.
If you can reach them, cut the leads off the potentiometer, disassemble the plastic parts, clean the leftover leads from the board and solder new one on.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thank you for pointing me in the right direction!
из
Добавьте свой ответ
Atomic Testing будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 263
