A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
131вопросов Показать все
iMac 2019 27" CPU change
Hello, I tried changing CPU ( i9 9900) and ssd, but after assembling everything, it does not start. I tried searching online what the cause could be, and looking at the diagnostic led i could not find a solution. As you can see from the image there is one led on, and if I understand correctly it is the #2. I tried disassembling again to see if there are some bent pins, but they are all fine. What could be the problem?
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Try reseating the RAM first, then the PRAM before taking it apart again. I had this similar problem.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Max будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 53
