Repair information for the iMac G4.
130вопросов Показать все
iMac does not power up
iMac powerMac 6.1 power PC G4
The computer had always worked fine then next time no sound, will not power up, just blank any suggestions?
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Наиболее полезный ответ
This model should be close to yours:
Apple iMac G4/1.0 17-Inch (Flat Panel) Specs
Identifiers: iMac 17" 1 GHz - M8935LL/A - PowerMac6,1 - M6498 - N/A
Unplug it, press and hold the power on button for 10 seconds then plug it back in and give it a try. Does it do anything when you try to start up, any lights any sounds?
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Unplug it, hold the power button for 20 seconds, then it should come on, if that doesn't work after you plug it in, press the power button
из
Ok I did what you said and after pluging it back in it makes a faint clicking noiise but still won't start
Оценка 0
Does the noise seem to be the same than the one in this video ? If yes, you see how to solve your problem ! Warm it and it will start but never shut the iMac down.
Оценка 0
Mine is doing the same thing, but not making any noise from fan. Tried to use the hair dryer, but no luck. Any other way outside of replacing the logic board?
Оценка 0
Добавьте свой ответ
johanne будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 2,376
