The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
90вопросов Показать все
Power light is white and stays on an no function
The power light is white and staying on permanently with air noise out of speakers. when I press the power the connection symbol lights up and nothing works . When I tried to reset nothing.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Function turns on after pressing "JBL connect" button and "+" button at the same time for 10s. To turn function off, you need to plug the speaker in power socket and press the "JBL connect" and "+" buttons simultaneously for 10s. After you can use Bluetooth.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
What does it do to the speaker exactly ?
из
Have the same problem with my jble e65 two white light blinking and then nothing. Tried the your solution but still nothing.
Оценка 0
1 Комментарий:
I have a Flip3 SE and I get no power up sounds,power button lights up and stays white all this with no functions at all
из
Добавьте свой ответ
Robert Cudmore будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 62
За последние 30 дней: 248
За всё время: 10,346
