Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
1041вопросов Показать все
Poor mic audio only on phone calls
Seeing a similar problem reported on this forum I followed the directions of replacing the Lightning Connector Assembly which includes two microphones and the headphone jack. This did not fix my problem. The problem is when on phone calls my outgoing audio through the local microphone is very muffled and low in volume. If I plug in the earbuds with mic then it’s OK through the headphone connection. If I switch to speaker phone mode then that’s OK too. I can record good audio while shooting video (both front and back camera/microphones) and can record good audio using other apps such as voice memo. But try to make a call then I have to use speaker phone or use headset which I don’t always have with me. I purchased the Ifixit Pro Tech tool kit and the replacement lightning connector assembly, installed it, and still find the same problem. While the phone was apart I made sure the mic ports were clear of debris. What else is suggested I try?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
If you’re outgoing call sound is muffled yet normal on speaker phone and earbuds it has to be the lightning dock assembly. One of the microphones isn’t working properly. The only thing to try is replacing it again. You could try contacting ifixit support.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Thanks, Chris. Just what I was thinking but...all of a sudden it's working. What the heck? If it hasn't worked for years and then still didn't work after replacing the lightning dock...but now after a day it has started working...what will prevent it from malfunctioning again? Why would it NOT work and then suddenly start working? Strange! Could there be a software issue or an audio chip issue?
из
@Gary Eldridge It is not a board issue and I doubt it would be software. Maybe a change in temperature? See how long it lasts. I would try it in housing if it reoccurs as the housing could have something to do with it.
из
It's been over a year now since replacing the lightning dock which contains the two microphones and my iPhone 6S Plus is still working great. Replacing the lightning dock sure fixed my issue with poor outgoing audio. Thanks again Chris.
из
Добавьте свой ответ
Gary Eldridge будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 1,182
