when I plug it would show apple logo for 3 sec then repeats
It constantly tries to boot when it goes to apple logo it reboots and shows apple logo on ipad 5th
Это хороший вопрос?
Это хороший вопрос?
hello Sufyan,
this is a typical boot loop. What you did before with it will be important. When did you notice it: after repairing or changing the screen, etc?. In any case, a workshop intervention is necessary (iPad is not for home repair with a boot loop). Most problems like yours come when you try to remove the motherboard or battery.
Был ли этот ответ полезен?
Hi! I had never had this ipad serviced or opened it was 1 year old. I dropped the ipad and the whole thing shattered. It was still useable. I left it in the car (Cold temperature) and when I came to pick it up in the morning it was stuck on a boot loop. The ipad never changed the battery or the screen.
we have the answer :-). Battery performance has dropped or damage in the past has made itself felt (bursting inductors - a constant problem with iPads). Connect iPad for longer with a high-power charger (12W), when the battery balance improves, the device turns on. It will take a while, about 30-45 minutes. Otherwise, the help of a repair shop will be needed.
- take care,
@tojaert Will a 10 watt power adapter work?
If it would do I have to charge it for about 2 hours?
yes that's a good idea to check. Leave it on for the whole day or night though.
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 69
Please help me fix this issue
из Sufiyan
