Replacing a zipper stop on topley coat
The zipper stop (the bottom part below the slider) does not line up with the slider and does not allow the zipper to work. How do I replace it? Thanks
Это хороший вопрос?
Счет 0
2 Комментариев:
Generally you would have to remove the entire zipper and sew a new one in to replace it. More detail would help, is it on the slider side or the other side?
Also depends on if it’s molded onto the fabric or metal and clamped on.
из
Thanks Shawn, it is actually the bottom part of a two way zipper now that I take a better look at it
из
Добавить комментарий
