Broken electronics ID question
I bought this off of a guy who said it was working then stopped. This part on the PCB is damaged. I need to know what it is so I can replace it. I do have the skills and tools to replace it.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Joshua Powell
That is an inductor, i cannot see the values well in your picture.
e,g. you can can search in electronics component stores, like element14, digikey, etc e.g. value, 1R0 inductor.
else you also can get from aliexpress, ebay, etc
Был ли этот ответ полезен?
Счет 1
6 Комментариев:
thanks! i was looking but needed a second opinion before i did anything else.
из Поделиться
Hi Joshua
No worries, you are welcome. the inductor is cracked.
try replacing and see if it works!
из Поделиться
the inductor has 280 or something like that printed on it
из Поделиться
@Joshua Powell that number is actually pretty important. It shows how many Henries your inductor is rated for. Three digit values are in nano Henries or micro Henries depending on manufacturers choice. The first 2 digits are the value and the 3rd digit is the multiplier. If yours shows 280 that means it has an inductance of 28 µH (28x0=28)
из Поделиться
Показать ещё 1 комментарий
Добавьте свой ответ
Joshua Powell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 31
За все время: 545
