Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
LCD identical to iPhone 4
I got informed by my iphone part supplier that the iphone 4S LCD is identical with iphone 4 (Verizon) LCD. Not so sure, can anyone confirm?
Это хороший вопрос?
Оценка -1
Добавить комментарий
5 Ответов
Наиболее полезный ответ
I have seen a picture that the one of the notches isnt the same but thats only one picture ive seen so far
Был ли этот ответ полезен?
Оценка 1
they are different. Just do an image search of the cdma, gsm and 4s iphone screens and you'll see the bracket is different. Just saw this a little bit ago. A co-worker had his all of 12 hours before it got dropped and smashed! Bummer!
Оценка 1
I had the same thing happen and I'm replacing the front panel as I type this reply.
https://www.etechparts.com/
They have most of the 4S parts already, but the digitizer and screen is a bit pricy, $117. I ordered yesterday and got the parts today for 12 shipping.
Оценка 0
Here is a guide to fit the CDMA screen which has different mounting screw positions than both the 4 GSM and the 4S. The guide is located @ Modmyi it has nice large images and has easy to understand steps..
Install a CDMA iPhone 4 screen on an iPhone 4S
Оценка 0
Just swap the bezel from your old frame. The connections are the same.
Оценка 0
Добавьте свой ответ
Anh Vo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 3,010
