The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
Thansmission locked in park.
2013 year. Gear shift will not come out of park. Transmission is locked up.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Problem may not be in your trans mission. I side the car near the brake pedal there is a sensor/switch the electronically actuates a lock on the gear shifter. Some vehicles will have a shift lock bypass button. You can google search where that button is located and or if it has a bypass for your particular year make and model.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
pauld будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 15
За всё время: 62
