Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154вопросов Показать все
My iPad 3 Lcd does not work after I snapped it in half
Ok, ok, I know it seems like a stupid question, but hear me out. So I bought an iPad 3 with a shattered digitizer but otherwise good lcd off of eBay. It wasn't ic locked, yay! So I set away at repairing it. However, the digitizer was broken into many pieces, and when I went to lift the LCD out of the iPad, some pieces of still-stuck digitizer pressured it and it got a diagonal crack. At this point half of the LCD still worked. Later on I plugged the iPad back on and the LCD gave no signs of life. iTunes doesn't work because it has a passocde either. Should I just get a new LCD or is the problem something else entirely?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@ameteur_repair there are never any guarantees but at this point my suggestion is to change the LCD/Digitizer and then re-evaluate. From what you are describing a new LCD should repair this.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Anonymous будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 24
