Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117вопросов Показать все
Will not boot form any drive
Just got this G3. I knew that it might have hard drive issues, so I plugged in my external firewire, and started holding down my option key. I selected the external drive, but when I clicked the arrow, the screen just blinked and nothing happened. The external drive boots other similar macs just fine, so I assume it is not the drive. Also tried several other install CDs, but again the machine will just not boot.
I connected to this mac in target mode from another mac and reformatted the HD and installed 10.3, but when I restarted, I just got a flashing question mark. I read somewhere that it could be corrupt firmware. I am not sure how to fix that. Any ideas would be appreciated.
Это хороший вопрос?
Оценка -1
1 Комментарий
Please tell me about the machine you are installing from and if your 10.3 is a retail version.
из
Добавить комментарий
1 ответ
Выбранное решение
Thanks for your interest. I just resolved the issue. Turns out that this G3 500 Mhz only had 64MB of RAM onboard and was not enough to boot into OS X. I added additional memory and the problem was solved.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
studio58 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 606
