The T Flight Hotas 4 is a joystick controller manufactured by Thrustmaster in 2015 that is used for specific flight simulation games. Model number 4169083 is currently supported by PC and PlayStation 4.
Sourcing a replacement potentiometer for t flight hotas
Try as I might, I've not managed to source a replacement potentiometer for my hotas. Is anyone aware of a company that might sell these parts? Thrustmaster customer services were no help at all and as far as they're concerned I should chuck my beloved flight stick on the scrap heap
Это хороший вопрос?
Счет 2
3 Комментариев:
I have a similar issue with the T.Flight Hotas X throttle potentiometer, tried cleaning original but no luck.
I’ve ordered a couple of pots that might do the job , I’ll post back here with details and part numbers if it works out.
If you have any details on the pot in question post them here and I’ll see if I can help.
из
did you find any potentiometer that worked?
из
None that were cost effective. I suspect that the answer below may have been the right one, but I'd thoroughly ruined the existing potentiometer by then!
из
Добавить комментарий
1 ответ
This may help. Replacement pots for TM HOTAS. https://www.radwell.com/en-US/Buy/CH%20P...
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
If you're having erratic yaw problems I found the fix for that. No parts needed. I just did this to mine and it works. https://imgur.com/gallery/ob06FmA
из
Добавьте свой ответ
Joe Lewis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 58
За всё время: 2,989
