Информация по ремонту и разборке беспроводных наушников-вкладышей Samsung Galaxy Buds+. Анонсированы и выпущены в феврале 2020 года.
Sound Balance issue, one bud is suddenly way too quiet
While using just the left bud, it suddenly got very quiet. I assumed the battery had run down, but it hadn’t. Both buds still work, but the left bud volume is MUCH softer, so as to be unusable.
I’m trying to decide if this is a mechanical issue or software issue.
The problem occurs across multiple devices, after unpairing/repairing, and with and without the Wear app. The software is up to date through the Wear app.
The bud is not visibly clogged, but is there a way to take off the metal sound screen for cleaning? The teardown video doesn’t show this.
Это хороший вопрос?
Счет 9
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Hey, I had the same issue. And literally, just minutes ago I pulled the bud apart. I just pulled with my fingers but that was risky I’m sure. A small knife or something thin like a pick girth might make more sense.
I don’t usually do my own repairs. But I have this face mixture I use for razer burn on my face. It’s like 95% rubbing alcohol.
I took a cotton ball doused it with the alcohol and lightly rubbed the inside of the buds. I used an air blower I have for my keyboard and made sure I didn’t leave any cotton inside.
The buds sound totally fine now. Saved me from having to send it to samsung and paying for them to just inspect it. Horrible Cx service.
Careful if you try it, but it worked for me. Hope it helps.
Был ли этот ответ полезен?
Счет 9
5 Комментариев:
This worked for me, thanks! I loosened the glue holding the metal grille to the bud with 99% isopropyl alcohol, then cut the glue around the edge with an "X-Acto" style knife, and pried the grille off. There was a smaller rubber filter that was glued to the inside of the metal grille, which came off with some tweezers and a little more alcohol. Sandwiched between these two filters was more than a year's worth of earwax, like some sort of cursed oreo. A cotton swab and some more alcohol wiped it clean away. I used the tweezers to remove any excess cotton hairs from the filters, then a quick blow of compressed air dried them off. A lot of the glue holding the whole assembly together came off in the process, but the silicone tips and friction seem to be enough to keep them from falling out once installed.
Once I did this to the quieter bud, it was suddenly louder than the other! So in the end, I cleaned them both this way, and a lot of the sparkle in the sound I remember from when they were new is back again!
из Поделиться
I want to confirm that taking off the little metal grid and cleaning it helped, but the amount of wax on the inside seemed to be minimal. Not sure if something I accidentally did in the process of opening or if it was actually the cleaning that helped.
I also managed with just a pair of curved pointed tweezers (from ifixit), which may be safer than using a knife for anyone trying this in the future.
из Поделиться
I can also confirm cleaning the metal grill and filter underneath fixed mine from cant hear anything to full sound again. Just heat the metal grill some to loosen glue and pry/pick out with very tiny point tweezer or pick and pick out filter attached to grill. Then just put back together, heat the grill in place one last time to re-adhere it. Easy simple fix.
из Поделиться
Lifesaver! Took the grill off with some isopropyl alcohol, exacto knife, and some tweezers. There was a seemingly small amount of wax build up, but after the clean everything is loud and clear.
из Поделиться
Cleansed! I had no idea that a thin film of wax could block that much sound
из Поделиться
i took out the mesh part behind the eartip and there was a small filter behind it and i took that out and gave the mesh a clean and the sound is way louder than brand new
Счет 3
Insert a needle in one of the holes of the mesh and gently pull it out. Clean it and place it back. Its fairly simple, Kudos!
Счет 3
There is a little hole at the bottom of the bud, just below the touchpad. Blow in it a few times, and the gunk should go away. I hope this helps.
Счет 2
2 Комментариев:
this somehow worked, made an account just to upvote this.
Didn't have to open it up, I blew on both the small holes
из Поделиться
Same story as Busta 👍
из Поделиться
The way I fixed this problem with my galaxy buds + was by removing the earpiece and cleaning them. make sure to remove the pieces and clean thoroughly.
another common problem can be that you haven't updated the buds, there is an app for both ios and android. look for it on the app store/ google play store. you might need to force update the buds
hope this helps
Счет 0
Same problem but with both of them. I'llbe watching YouTube, or listening to Spotify or Amazon Music, etc and volume will go down close to nothing, then come back a few seconds later, then happen again minutes later
Счет 0
Добавьте свой ответ
jordan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 31
За последние 30 дней: 112
За все время: 11,497
