2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580вопросов Показать все
MacBook Pro not booting
Hi
My macbook pro late 2013 15 inch not working after replacement of speakers which requires the removal of the logic board as they are under the board.
Here is the current behavior:
1) Pressing the power button spins the fan but no chime happens
2) No logo, no light on the apple logo on the back, no keyboard backlit when pressing the backlit buttons, pressing the volume buttons does nothing, brightness buttons do nothing as well
3) When doing NVRAM reset I hear the chime and I can repeat it.
4) When I release the NVRAM buttons and the computer starts still no light however pressing the volume buttons I can hear "voiceover on" or "voiceover off" so it looks like it's on the login screen and it activated the accessibility. Pressing the power button off to force shutdown and reoperating, it again stops working and I no longer get the sounds of voiceover and I have to do the NVRAM again to get the sounds.
5) SMC reset does nothing
6) Battery is so swollen that when I removed the back case, I can it attach it again even though it shows normal health and holds charge for 4 hours. Can the battery damage the logic board?
7) Do I need to do the NVRAM a certain number of times?
I was very careful when I was disassembling the board so I hope I haven't caused a damage to the board or any of the cables :(
8) What cables or connectors that I may have not connected properly that would cause this behavior?
Thanks in advance
Regards
Michael
Это хороший вопрос?
Оценка 0
2 Комментариев
Have you tried booting from external flash drive?
из
@Michael Ayukawa haven't tried that but not getting anything at all on the screen could be an SSD issue? Like if you remove the SSD at all would not that automatically start the internet recovery process?
из
Добавить комментарий
1 ответ
Выбранное решение
It turns out that the far left pin on the display data cable bent over the 29th pin and its tip was broken as well :(
Thanks God, I managed to realign it back to its position and the screen is back on even though the tip is broken and the pin is no longer straight compared to the other pins.
Be EXTREMELY careful when dettaching this cable as it's very fragile.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Michael Azer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 60
