Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
112вопросов Показать все
Do you need all logic board screws for Laptop to power on?
Missing all 5 (+1) screw being careless when taking MacBook apart but now it won’t power on and all cables are attached. Are all screws on logic board required for power to happen or am I missing something else?
Update (01/15/2021)
Is there something missing
Это хороший вопрос?
Оценка 0
1 Комментарий
Dan, is this Insulator known by any other name. I am having trouble locating a replacement.
из
Добавить комментарий
1 ответ
Выбранное решение
Yes, you do need to mount the logic board fully. There maybe one or two mount points that could be left un-mounted. I’m sure no one has made a detailed study on which ones and if its safe to do (don’t play Russian roulette).
Here’s the needed screws MacBook Pro 13" Screw Set - Logic Board (x5)
You talk about a sixth screw Using the MacBook Pro 13" Two Thunderbolt Ports 2019 Teardown can you point it out.
Update (01/15/2021)
Looking at the guides I do see you lost the insulator
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I replaced the screws thank you Dan. Think I may be missing something else though might have been a silver piece near the power button area. It’s all I can think of since the unit is still not powering on and was prior to me disassembling
из
Добавьте свой ответ
Anthwon Newton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 17
За всё время: 533
