Repair and disassembly information for the Samsung Galaxy Note20 Ultra Android smartphone. Released in August of 2020.
Front facing camera not working after service pack replacement
I recently repaired a friends Note 20 ultra screen with a service pack. The repair went well with swapping all the original parts over. However when we booted the phone the front facing camera will not work. I went through and pulled the original camera from the original housing to try that. Since the service pack came with one in place I thought maybe it was faulty. However even after using the original and going through and factory resetting and doing everything I could find online to do still no dice. The front facing camera still will not work. Anyone run in to this issue or know how to potentially remedy this?
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
You need to use the original front camera or buy the same version.
Был ли этот ответ полезен?
Счет 1
Cameras are serialized to the motherboard both front and
Счет 0
1 Комментарий:
Its a part you need to make sure the description of part says serialized
из
there is a bad update that’s been out since the beginning of this year for s10/note10 and up. It has been making the front camera not able to be recognized by the motherboard. I have had it on a few note 10s, s20s and note 20s. No matter what camera you try, usa international or original havent worked for me. Many people have had this issue after they updated their phone.
Счет 0
Добавьте свой ответ
Kyle Tanner буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 2,068
