Nintendo 2DS - это упрощенная версия Nintendo 3DS, которая всё же содержит такое же аппаратное обеспечение, сходную функциональность и совместимость с программным обеспечением, разработанным для Nintendo DS и 3DS. Однако 2DS отличается своим новым плиточным форм-фактором от дизайна раскладушки, используемого её предшественниками, а также отсутствием характерного Nintendo 3DS автостереоскопического 3D дисплея.
205вопросов Показать все
My 2DS keeps asking me for a pin that I don’t know
I’ve had my 2DS for a while now and I think it was hacked when I bought it, but for a while now whenever I turn it on the screen is black and it says “Enter the pin using ABXY and the Dpad to proceed”. It doesn’t let me do anything, not even play or go into settings and I never put a PIN, or at least not that I remember. Is there any way to fix this?
Это хороший вопрос?
Оценка 0
4 Комментариев:
did you ever find a way around this? my 2ds has just done the same thing and i haven't got a scooby doo how to bypass this pin
из
Hi, i did provide an answer below a long time ago, let me know if it works for you.
из
@devnol the issue is i can't physically access the ds to get to the settings, it's literally bricked on the "enter pin" screen even tho i have no idea what the pin is, it's a 6 digit combo with abxy and the dpad
из
@haydentcity Oh, i'm sorry. Black screen means your console has a pin set from some homebrew app, probably Luma3DS. I don't have a 3DS to test right now but either the NH Discord (at 3ds.hacks.guide) or the r/3dshacks subreddit will definitely be able to help.
из
Добавить комментарий
1 ответ
It appears that your console is parental locked. You can call Nintendo but that takes time so I’d suggest you use this procedure instead:
- Go to settings and see if you can get the parental controls prompt to pop up
- Choose forgot password on the bottom of the keyboard
- In the security question, choose forgot again
- Make a note of the Inquiry number
- Go to https://mkey.salthax.org/
- Choose 3DS
- Put the current system date (in case it’s wrong or something
- Leave Additional Data empty
- Put the number you made a note of above in the Inquiry Number field and hit Go
- Take the new number and put it on the number field on your 3DS
- The console should now be unlocked, go to the parental controls menu and disable it fully.
I hope this helps! If you have any questions feel free to report back (pictures of your screen are preferred so the community can understand better.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
LM11 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 24
За всё время: 658
