MBP charging very slowly and registers 61W charger as 12W, any help?
Hi
My 2016 MBP has had no issues until one morning it would not recognise charger. It had ran out of charge overnight so I had v. limited options as it would not turn on. Took to local computer guy, unsure what magic they did, and it turned back on again.
However, it is charging very slowly and sometimes drains if I try to use it when plugged in. It did say ‘service recommended’ but SMC reset has fixed this. Also, the 61W original apple charger is being shown as 12W on coconut battery (and the Mac software), the ‘charging with’ ranges from about 0.18watts to 6.0watts.
Is this a common problem? Any suggestions greatly appreciated!
Это хороший вопрос?
Does it display the same info on both USB ports?
из Chris Stables
Yep, I have also tried 3 different cables (2 apple ones, 1 came with a non-apple monitor)
из Sarah Hollywell
