Repair guides and support for the first generation of C/K pickup trucks.
3вопросов Показать все
Вопрос закрыт
How can I change my alternator belts?
Replaced the alternator for my '65 Chevy C10, now need to put the belts back on but they don't reach if i just pull them. How can i get the belts on with the least skin off my fingers? It is a 327 V8 and the belts rotate only on the alternator, engine and radiator/water pump.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Okay, it would help to know what engine size you have and what accessories you have. i.e. power steering etc. Usually all you have to do is loosen bolt 4 and bolt 7 in the diagram , push the alternator toward the engine block, You then take the belt and place it over the corresponding pulleys. I then usually take a hammer handle or a medium claw bar and gently move the alternator on the bracket away from the block until the belt is tight. Tighten bolt 4 and 7 and recheck the slack in the belt. The accessories and the engine size determine the routing and size of the belt. I hope this makes sense and does help you out.
Был ли этот ответ полезен?
Оценка 4
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 2,088
