Please help me install OS 9 on iMac G5 and older Macs
I have a source for pre OS X os for Macs. I’m unsure how to create an install flash drive from an Intel High Sierra machine. I’ve four G4/G5 machines that I’d like to setup.
@danj you there ?
Это хороший вопрос?
Оценка 0
4 Комментариев
You know, I need my beauty sleep ;-}
из
They tell me that as I get older I'll sleep less. But they never mentioned anything about beauty <LOL>
Besides the subscription board for microsoldering ($29/month) where do I post a question?
I have a lead that snapped even with the board and I can't get it to take solder (a Mac Mini).
из
I need all the help I can get ;-}
iFixit Answers is free! Where did you signup a subscription board for micro soldering?
из
Are we the blind mice leading each other through the maze ?
Now networking is something I can handle. I think. Lol
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
So first thing this model won’t boot from a USB drive ;-{
You have to use either a bootable CD/DVD (DVD+R DL/DVD±RW/CD-RW) or a FireWire drive (400 MB/s).
You also have a bit of a chicken and egg problem too! You need a working OS-8/OS-9 system to prep the optical disk or FireWire drive if you are expecting to run OS-8/OS-9. This series also supports OS-10! The highest supported level for your G5 systems is OS-X 10.5.8 and for your G4 systems it is OS-X 10.4.11 (15”/17” Flat Panel systems).
Frankly, I would go with OS-10 on these systems as it will be easier to get the needed grey or retail version of the disks.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
I hope using a comment is appropriate.
I have two Snow leopard installs. That's OS 10 but Intel. Chicken and egg is right. I gather that even if I have a disk image file for them it can or cannot be created on an intel machine ?
из
The original Snow Leopard installer CD/DVD is a fat installer with both PowerPC and Intel elements, you need the disk!
из
Isn’t that unavailable anywhere ?
из
Добавьте свой ответ
James Walker будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 11
За всё время: 270
