Possible to add a blade SSD to the original base model A2116?
In the A2116 teardown (the base model with no Fusion Drive), the connector for the Apple blade SSD is not loaded, and hence you cannot upgrade the miserably slow hard drive to a blade SSD.
Question : Could you upgrade this just by adding the SSD connector, or are there other components required to support the SSD that are also not loaded?
Это хороший вопрос?
