A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563вопросов Показать все
NDC001 error code after screen change
Hello, I bought a 2017 MacBook Pro A1708 without Touch Bar with a broken screen. After changing the screen and doing a diagnostic I have the error code NCD001 which means the camera is not connected and therefore not working (FaceTime and photobooth). After performing the following operations: SMC, NVRAM, it still does not work. Has anyone had the same problem as me and if there is a solution I'm in! Thank you
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Hey did you ever get it figured out?
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
No, I didn't found the solution
из
i’ve same problem too!
Оценка 0
1 Комментарий:
wonder if anyone managed to figure it out. Im thinking it might be the flex cable that was damaged?
из
Добавьте свой ответ
Noémie THOMASSET будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 16
За всё время: 307
