iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
873вопросов Показать все
Random colored lines after reconnecting screen to logic board
So I don't know what I did but those lines appeared when I reconnected the screen and lcd cables again. the screen is not cracked or the LCD I think I broke something idk what but that screen worked just fine before I did that I really need help on this
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
It could be that the connectors are not fully connected into place. Double check all the display connectors to make sure that it is connected properly. If it still has lines on the display, inspect the cables to the screen as well as the connection points on the board to make sure nothing is torn or damaged.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Ok so I have disconnected a lot of times the screen before this happened I checked and nothing appears to be damage but I know that while I was opening it I tore a little bit the top ribbon cable were the ear piece speaker is do you think that is the problem
из
@alexiolabest It sounds like the display cable has been torn, even slightly can cause that problem. You are probably going to need a new display, as I do not think that you can repair that.
из
@carsman248 thanks for the advice I thought that the top ribbon cable was for the sensor and I didn't have any affect because the two bottom cables look in mint condition so I guess I gotta buy a new screen and a battery
из
Добавьте свой ответ
Alexis perez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 50
