Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
387вопросов Показать все
Ps4 pro not updating to 8.03 from 7.00 (Error su421186).
Disk worked on my PS4 but I still get the error. Updating in safe mode doesn't work. Inserting disk doesn't work. Inserting disk in PS4 disk tray does open it up. Therefore the BD Rom should be communicating with the motherboard, right? Ps4 doesn't take any discs. No discs stuck inside. Can fire it up so it's not stuck in a boot loop. Also, can't find any tutorials about the ribbon on the ps4 pro.
Am on 7.00 updating to 8.03
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It appears to be a broken ribbon connector between your bd drive and motherboard I'd try replacing that
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Just be gentle with it mate I've busted one myself
из
Where's that ribbon though? All videos are for slims or normal ps4.
из
Добавьте свой ответ
Rob будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 140
