The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
30вопросов Показать все
iPad lcd self replacement
I have my sons iPad mini 5 and the left side is white and has a couple lines going through it but i can still use it with no problem, in order to replace the LCD would I have to buy a new screen as well?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The LCD and the screen is the same thing.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
This is False The LCD and Screen Digitizer are two Seperate Parts If the screen is not cracked but there are pressure cracks Then yes you would only have to replace the LCD
из
LCD stands for Liquid Crystal Display, so that is not the touch sensitive part. I know they are separate parts, I have been fixing phones for years.
LCD and screen are the same thing, but LCD/screen and digitizer are different.
из
Добавьте свой ответ
Maria velazco будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 46
