MacBook Pro won't start and won't charge
I have a MacBook Pro (Retina, 15 inches, Mid 2012), recently replaced the battery ourselves with an ifixit kit (MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery, Fix Kit. SKU: EU117047-5). This was fitted at the beginning of February and had given the mac a new lease of life.
But unfortunately, it was being used last week it ran out of charge even though the MagSafe charger had a green light on it, it ran out of power.
I have since tried another power supply that has the same green light on, and also not charging. I have tried resetting the SMC but nothing seems to work or power it up. If I press the power button the no charge icon appears on the screen and the MagSafe light stays green.
Has anyone any ideas? could it be the logic board or is there anything else that can try?
Это хороший вопрос?
3 Комментариев
Do you still have your old battery? If you do carefully unplug the installed battery and give your old battery a try placing your system on its side so you can still access the MagSafe port.
Does the charger LED go to Amber and/or will it startup even if you only see the fan move a bit.
из DanJ
Hi Dan, thanks for the advice. I connected the old battery and the system rebooted and worked, but there was very little power in the old battery and it kept shutting down, but it did reboot. The LED stayed on green and didn’t go Amber, so wasn’t charging the old battery either. Does this mean the logic board is ok? Or does this explain something else is broken. Could it be the MagSafe DC-In Board is faulty? Or does anything else come to mind?
из Neil Jeremy
Further update.
I restarted a few times and couple of times it fully starts up being able to log on, I can see the battery says it’s at least 30% power. But then shuts down before I can do anything else.
Tryed a few more times and now the boot up bar gets to 2/3 along the bar before shuts down.
из Neil Jeremy
