The second iteration of Apple's popular wireless earbuds, released in March of 2019. Identifiable by model number MV7N2AM/A.
My right airpod doesn’t work
My right AirPod doesn’t work again and I can’t see the icon on my widget too, but the left AirPod works perfectly fine. Whenever I put the right AirPod in the charging case the green light starts blinking.
Это хороший вопрос?
Счет 8
1 Комментарий
Maybe your right airpod battery has an issu , it can be repaired.
There is a lot of videos on Youtube explaining how to replace it, but it requires very fine soldering skills and some specific hardware to maintain and heat the airpod (mine is dead too).
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I’d recommend buying a cheap authentic replacement from eBay which only cost around $25 usd
Был ли этот ответ полезен?
Счет 3
My left AirPods is making a lot of noise, how can I fix it
Счет 1
I also encountered the same problem. After browsing some materials, I learned that it might be a common issue with AirPods 2. If it's not a battery failure, it's highly likely that it cannot be repaired. So far, none of the repair shops I have consulted have fixed any cases. I can only replace this right airpod, re-pair it, and update the firmware.
Счет 0
Добавьте свой ответ
obinna буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 17
За последние 30 дней: 70
За всё время: 2,559
