Fob will not program
Key fob procedure don't work,the driver's door doesn't do the procedure
Это хороший вопрос?
Счет 0
2 Комментариев:
going to need more info.... whats not working? what part of the procedure?
what is the procedure that youre doing..... the more info you give the easier it is to help
из Поделиться
Hold on the unlock button until it clicks then click the key to x real quick then hold down on both the unlock and lock button on the remote is the procedure that I was doing but when I hold down on my unlock button when sitting in the driver's seat it does not do the unlocking thing that should if it's like most Chevrolets
из Поделиться
Добавить комментарий
