PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387вопросов Показать все
Will the Ds4 work without a charging assembly or touchpad
I lost the charging assembly and don’t know which one is compatible with the controller model cuh-zct2u and the touchpad is broken. Will the controller still turn on and connect to my PC even without a touchpad and charging assembly? And the way that I will charge it is by using the ext port on the bottom of the controller.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It should but there won't be any light coming from the controller as the LED is on the charge port module
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
djo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 83
