Screen problem with my PowerBook
The screen of my PowerBook looks no good. 1/3 of the screen have a perfect image but the other part of the screen have a few lines and mirror image. Before with a few movements of the screen the problem was resolved, but now not work. The LCD replacement can be the solution?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Here: PowerBook G4 Aluminum 15" 1-1.5 GHz Display Data Cable Replacement
On step 21, make sure the cable is in snugly. It seems like an issue with the data cable. If it doesn't work after that then make sure it's plugged in tight on the display as well, although I can't imagine that happening as it's usually secured with tape..
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
vemsin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,337
