Repair guides and support for the first generation Town Car, a full-size luxury sedan manufactured by Lincoln.
Why is there oil on my spark plugs like alot my lincoln town car
i changed my plugs cause i had a misfire an when doing so had a lot of oil on my plugs an coil packs 2007 town car 4.6
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Sounds like you might need a new valve cover gasket. Check to make sure valve cover isn't cracked. If it isn't then the gasket is most likely the culprit.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
shawn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 276
