A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
569вопросов Показать все
Connection with the joystick is weak.
Long ago I opened the ps4 slim for simple cleaning. After that I started having problems with connecting the joystick to the console. I basically can't use it if I stay more than 1 meter away from the playstation. It is as if I had disconnected the receiver that communicates with the joystick even though it is connected "correctly". I would like to believe that I did not damage the receiver.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi!
I recognize this issue. You probably damaged the antenna. I think it will work after you replaced it for a new one.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Caio Souza будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 88
