Can’t turn on,
Can’t turn on, when plugged to charge it turn on immediately by self but can’t control, can’t connect . When unplugged it immediately turn off by itself also
Do you know what is issue?
Это хороший вопрос?
Это хороший вопрос?
I have the same problem. What's the solution?
Был ли этот ответ полезен?
its in demo mode?, if i remember press and hold the Power button and play button simultaneously until it turns off, then you can turn it on and do a reset by pressing play and volume up button until it turns off, then you're good to go.
That didn’t work for me now what?
After a few tries, I was able to fix it with this tip! Thank you 👍🏻
Any progress on that problem? I'm having the same problem now.
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 38
За всё время: 2,040
