The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262вопросов Показать все
DSi: bottom screen flashes + stripped screw
Hello, good day.
I have a pretty old Nintendo DSi system with lots of old memories. Unfortunately, it started to not boot after a couple of years. The bottom screen will flash white while the top stays black and it’ll power off. I tried opening the system up to see what the issue is, but one of the screws on the back accidentally got stripped due to some pieces of the rubber getting stuck in the hole (the right one circled in the image).
How would I go about opening the system up with a stripped screw? Would I just have to force pry the back off or would it damage the motherboard? Even when I do get it off, what should I look for?
Any recommendations will do.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
to get the screws out you can try and give this a shot
Precision Screw Extractor Set
Precision Screw Extractor Set Изображение
Продукт
$24.99
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
angel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 96
