Why is the new battery not powering the device?
I received my new battery for my nest 2nd gen thermostat from I fix it. After I installed it, I charged it with a USB charger. After several hours of charging, the Nest device won’t turn on. When I plug it into the wall, I get a red blinking light at the top. I know I’m installing the battery correctly because, I was able to install the old one and get it to work. Is there a problem with the device or the battery? Thanks!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
your best bet would be to contact customer support about getting a replacement battery. sounds faulty. ifixit is usually good about solving this for you.
good luck
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Brad Burns буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 173
