Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Вопросов 20 Показать все
Moire pattern on my screen after digitizer replacement
The digitizer glass on my mini 3 broke and I replaced it per instructions. What I noticed is that after installing it, there is now a rainbow/moiré like pattern on the top right that covers about 1/4 of the screen. Is this a defect in the digitizer glass? No screen protector and no obvious signs of cracked LCD…
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Hello,
I would first try disconnecting the digitizer and powering on the iPad to see if it still shows those symptoms, If it does its obvious that the LCD has been damaged and you need a replacement LCD! :D
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thanks, I tired it and it's not visible with the digitizer flipped up. As soon as I put it over the LCD, the pattern appears.
из
Then, it's the cable itself. You need a new digitizer! :D
из
Добавьте свой ответ
Jerry Lee будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 90
