In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423вопросов Показать все
Ifixit Battery less than 1 yr old, swelling inside my Mac
Purchased my new battery less than a year ago from Ifixit. days ago, the computer won’t close, by last night the key board was bowing, scared the battery was going to explode. What do I do? Waiting to hear from ifixit….
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I definitely wouldn’t try to charge it anymore. contact ifixit customer support about the issue, I’m not sure how long their batteries are warrantied for but they would be able to assist you with it. a bulging battery could prove to be a fire hazard and should be handled with care!
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Thanks Dan, I did reach out to ifixit CS and they were super helpful, you too
из
@Margaret Ryan - No problem! Don't forget to score the answer and accept it - Logixal will appreciate it!
из
@danj thank you sir! and @margaret ryan im glad they were able to help you! Ifixit is a great company!
из
It is possible that the battery was damaged by external causes such as a failed power cable. First off, I would replace the battery (whether it is covered under warranty would be up to ifixit). Second, I would replace my charger and cable to rule out those as an issue. You may be getting improper voltages that are causing premature degradation of the battery and in your case, swelling.
Оценка 0
1 Комментарий:
Thanks Robert, but no issue with cable. Battery out and one of the batteries is swollen, really swollen. Bad battery, that’s all
из
Добавьте свой ответ
Margaret Ryan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 179
