Air conditioning compressor waits to come on for about 3-4 minutes?
First started after no use winter. Once it starts working it works fine. Parts store quick coupler gauge shows in green when compressor running.
Это хороший вопрос?
Это хороший вопрос?
cooling system compressors normally start immediately from an off condition. HOWEVER, if it is turned off then back on immediately, there is a time delay of 3-5 minutes to allow the internal pressure to dissipate. That pressure will stall the motor on startup and burn the motor out.
Был ли этот ответ полезен?
On start up the air conditioner is off. Once running engage air conditioner and do not touch after that. Compressor not trying to come on at that point if that’s what you were thinking. Takes 3 to 4 minutes for the compressor to kick in.
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 104
