The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
53вопросов Показать все
Why is my phone the only one with this problem?
So about 3 days ago my phones wifi was fine. Now however I can’t use wifi. i’ve tried restarting my phone. Disconnecting and reconnecting, resetting router. Nothing seems to work. It there any reason why this is happening to only my phone?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
You said you restarted your phone. Did you try a complete hard reboot by holding down your phone's power button and selecting “Restart" from the popup menu?
If that doesn't work, try resetting your phone's network settings. Go to the Settings app and type “Reset Wi-Fi, mobile, and Bluetooth” in the Search bar. Select the option and follow the prompts.
You will be asked to re-select your Wi-Fi network to connect to it .
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Tyrell-Chan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 34
