Очиститель воздуха с фильтром True HEPA производства компании Brondell. Выпускается в черном или белом цвете (P400-B или P400-W).
Device does not reset or turn on - How to find spare parts?
We were given a broken Brondell (also branded Aktobis or Winair) air purifier. It stopped working when changing filters and Brondell doesn’t offer repairs or spare parts. [Edit: We followed all reset procedures suggested by the owner’s manual]. The device briefly turns on before turning off again. Resetting does not appear to work. There are no apparent damages to the boards (there are three, the main control board, the CO2 sensor and the user controls)
We have already tried replacing the power cord to no avail. We can’t find the problem, and can’t find spare parts that’d enable to switch and test the boards. Any recommendations?
Это хороший вопрос?
Счет 1
1 Комментарий
I’ve had the same unit with the same issue for over five years now. Have you ever been able to figure this out?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
if you do not have a manual, go here:
https://www.brondell.com/media/wysiwyg/a...
follow directions which include resets.
For it to stop when the filters were replaced would indicate a replacement procedure error.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Hi! Thanks a lot for the help. We already tried everything in the owner's manual (as well as contacted Brondell, which indicated that there was "nothing to do about it"). Sorry, I should have said that in the initial post!
из
Добавьте свой ответ
Emeline Brulé буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 24
За все время: 558
