CB Radio (all types) first introduced in 1958.
Wiring diagram and colors for Cobra 29 LX Max microphone.
All of the wires came unsoldered from the plug on my microphone for my Cobra 29 LX Max. When I take the microphone apart, it appears the two extra wires are for:
Yellow = Extra microphone for the phone audio.
Green = Possibly data for the three buttons on the front. Such as Repeat, Report and Bluetooth.
From watching videos online, I can probably figure out the other four, but I’m not sure how to test for the extra Mic and Bluetooth on the radio side. Not sure which pins they go do. The only pin I’m sure about at the moment is ground is pin #1 as it’s the only one that didn’t get broken off.
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I found my multimeter and watched several videos. I figured it out. This is according to the pin numbers on the plug for the microphone.
Pin 1 = Ground = No shielding
Pin 2 = Audio = Black
Pin 3 = Transmit = Red
Pin 4 = Receive = Blue
Pin 5 = Blue Tooth = Green
Pin 6 = 2nd Microphone = Yellow
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Also note, If audio only works when you turn on Talk Back, then the Receive wire is never making connection to ground when the key is depressed. The audio is MUCH louder when the receive wire is connected properly.
из
Screwdriver
BellsCB.com
Счет 1
Please guide me in VHF Radio company I.Com model 5023
Счет 0
Добавьте свой ответ
jdavis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 15
За последние 30 дней: 60
За всё время: 5,937
