Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
1697вопросов Показать все
My ps4 has a problem
My ps4 wasn’t accepting discs all of a sudden,It was accepting yesterday night,today morning I woke up I tried to insert,I couldn’t insert,I have to fight the PS4 to push the cd, I accidentally pushed it thinking my ps4 would work,but I couldn’t play the cd and the cd isn’t coming out,how do I fix it
what Do I do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Looks like the disc drive has failed and firstly you need to check if the Disc drive is powering on when you turn on the console. If it is, open the console and check the rollers that accept the disc and eject it, most of the times cleaning it will solve your problem.. If the disc drive isn't receiving power then you’ll probably need to replace the drive itself. Cheers :D
Был ли этот ответ полезен?
Оценка 0
7 Комментариев:
I tried to insert the disc I couldn’t there was literally no disc there i pressed eject there was sound coming I force inserted it(thinking game would play )but it didn’t and then still I pressed eject sound is coming but no disc is getting ejected and the disc isn’t showing on ps4
The disc isn’t actually showing and I can’t play it
из
You will then have to open the disc drive and probably clean it and the rollers and then check if it plays the discs.... There might be a problem with the Disc Drive itself so your best bet is opening and checking.
из
How do I not damage it
How do I fix this without opening any components
из
If i'm right there is no possible way of fixing it without opening it....
из
How do I open it safely?
из
Показать 2 больше комментариев
Добавьте свой ответ
Habeeb Afraz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 41
